Suggestion: OSSC mask offset option
NewHome Forums OSSC, OSSC Pro and DExx-vd isl OSSC – Feature Requests Suggestion: OSSC mask offset option
  • #15241
    TennokoeJames
      Hi guys,
      Just got my 1.6 and it’s awesome!
      I can finally retire the Lagmeister.
      The masking feature is real nice, for covering the big colourful bars and junk pixels, but every machine displays it’s picture in a slightly different place and they are never centred.
      Would a mask offset option be possible?
      Where you can not only set the number of pixels that the mask covers, but also set the horizontal and vertical offset?
      #16492
      rgdelato
        I don’t know if it’s possible, but another version of this idea might be to have four mask values instead of two: top, bottom, left, and right in pixels.
        #16537
          You can tweak adv. timing options (h/v backporch) to center picture position.
          #16548
          TennokoeJames
            I’ll give that a try. Thank you.
