Super Famicom and OSSC
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › Super Famicom and OSSC
- This topic has 14 replies, 5 voices, and was last updated May 27, 2018 at 6:43 PM by igo12.
April 25, 2018 at 6:46 AM #21103Hello, I ran into a problem on my Sony TV Bravia 50w808c. When connecting to SCART RGB “Super Famicom” produces such a picture.
 Video Yotube
 I’ve tried different options for connecting the synchronization in the super famicom connector.
 3 contact – the picture is constantly shifted horizontally by a couple of pixels.
 9 contact – problems like on video.
 7 contact – Everything works, but sometimes the problem is like on the 9th contact.
 8 contact – no picture.
 I tried the 9th contact through the lm1881 circuit. The result was similar to using 3 contacts.
 I found another serious problem with the image lines moving apart:
 I conducted checks on several TV effect as the pictures are saved everywhere but the problems like the video disappear. I still have PS1 PAL / NTSC, PS2 PAL / NTSC, Sega Mega Drive NTSC-J, Super 32x NTSC-J with them there is no problem with standard connection in SCART RGB.
 To solve this problem I want to buy OSSC but the information is very contradictory somewhere it says that the problem will also help in the erroneous translation of 240p to 480i and somewhere that does not help the problem with the frame rate famicom. Please tell me, will OSSC help in my case, especially with regard to the problem as to images with mismatched lines?April 25, 2018 at 9:30 AM #21104Feeding the image directly to the TV means the TVs deinterlacer will be processing the picture when it should be handled as a progressive image. This can cause all kinds of problems. Will OSSC fix this particular issue? Probably, but remember SNES is one of the most problematic systems and you might need to fit a de-jitter board to your console too (https://videogameperfection.com/forums/topic/nes-snes-240p-audio-video-stability-issues-read-before-posting/). April 25, 2018 at 3:08 PM #21112Anonymous Is there an ETA on the dejitter board? It seems like it will be a nice upgrade, and I like upgrading my consoles. 🙂 April 25, 2018 at 4:46 PM #21115There’s about 5 being tested at the moment, just a handful of minor issues still being investigated. April 26, 2018 at 7:13 AM #21152Thanks for the quick response, I have new information my Super Famicom when outputting to 480i disappears the problem of dividing the lines in different directions at the top. I hope this information will help determine whether the OSSC will solve my problem with my TV.
 Modifying the console option is also interesting as the last chance I would like to not disassemble my famicom.April 26, 2018 at 5:48 PM #21174Looks to me like it could be related to the jitter issue, since it only affects the top half and then gradually corrects itself. Your observation on 480i output further strengthens that. However, the digital processing is probably different to the analog in, because I’ve never heard this is a problem on the Sony W series when running through the OSSC. April 27, 2018 at 4:03 PM #21197The jitter mod is pretty much complete according to Marqs over on shmups: https://shmups.system11.org/viewtopic.php?f=6&t=61285&start=90. I’m getting one for my NES and my SNES, hopefully that will fix the audio issues I have with anything above line2x on those two consoles. All the others seem to work fine beyond that (except 480p x2 on my TV, for some reason). May 7, 2018 at 6:34 PM #21409Anonymous How can one acquire a dejitter board? My google fu may be weak. I see mentions here and on shmups about them starting to become available, but nothing clearly about “get them here”. Sorry if I’m being dense, any help appreciated. May 8, 2018 at 8:02 AM #21426Pretty sure VGP will have them for sale quite soon. What’s out there now is people DIYing it, and there was a group buy for parts/assembly in the shmups thread recently. You could try posting there if you are desperate. May 8, 2018 at 11:43 AM #21427Yep we’re just waiting for the initial batch from the suppliers. May 8, 2018 at 3:02 PM #21428That is awesome! I have some coming from the fellow in that thread. I am hoping that someone will put together an NES guide for it, specifically a toploader with an NESRGB in it. Those are the only two systems that don’t work in 5x on my TV and really it’s just the audio that doesn’t work, so I can’t wait to get them fixed. May 8, 2018 at 6:34 PM #21437Anonymous I’m just looking for a bare pcb. Marqs posted the mouser bom, which is extremely helpful, and im pretty confident I can diy it, with the exception of being able to fab a pcb. If anyone has a spare here, I am interested. I will ask at shmups also. May 8, 2018 at 7:48 PM #21439There is a link in that shmups thread for an OSH Park file, you can get the PCB (well, usually a minimum order of 3) from them for pretty cheap. May 8, 2018 at 9:55 PM #21443Anonymous I didn’t find it in the thread, but did find it in the readme on github. https://oshpark.com/shared_projects/XwqVt6Gq thank you for pointing me in the right direction, noodohs! May 27, 2018 at 6:43 PM #21880Hello.
 I got my OSSC and it successfully coped with the problem. The super famicom picture became very beautiful.
