SUPERCIC – Distorted picture
NewHome Forums Repairs and Upgrades SUPERCIC – Distorted picture
  • #42522
    rogerxy
      Hi
      I’ve installed borti’s SuperCIC/De-jitter on my 1CHIP PAL SNES.
      After the installation the game starts, the sound works and the 50/60-switch also seem to work.
      However, the picture is strange. Sometimes I get sound and black screen, then it can suddenly change to showing a picture but distorted:
      https://ibb.co/mJ7CzZ0
      https://ibb.co/MMxqV6Q
      I have doubled checked the installation manual, checked for shorts, checked that the required pads on the PCB has contact with it’s pad on the SNES PCB.
      Could it perhaps be something related to S-RGB? CS.i and CS.o (raw) goes to pink 7 on S-RGB and /Vmode goes to pin 9 on S-RGB.
      Any suggestions are deeply appreciated.
      Thank you
      /Roger
      #44329
        Does this only happen when you play e.g PAL games at NTSC timings?
        #44430
        borti4938
          Do you have any installation pictures? Otherwise it‘s somehow hard to say what is causing your issue.
