Sync lost when switching lights on/off
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › Sync lost when switching lights on/off
- This topic has 18 replies, 6 voices, and was last updated April 2, 2018 at 5:09 PM by
y0da.
June 2, 2017 at 1:30 PM #13094
Hello.
In my new house, I loose sync when I switch the lights on in my game room.
It happens also when I turn something on in my other rooms.
The house is not grounded.What should I buy to avoid this issue once and for all?
Should I only connect the OSSC or the other consoles too?Thank you for your help.
June 14, 2017 at 10:34 AM #13242I’d be curious if you do ever find a solution to this, we had another issue where a customer lost sync whenever his fridge turned on.
June 14, 2017 at 2:20 PM #13247I may have a clue at 1:50 in this video.
But I want to be sure before buying anything.
Additional informations are welcome.June 15, 2017 at 12:23 PM #13258I’d be curious to know if they actually work too, seems a bit like it could be snake oil but I don’t know enough.
June 15, 2017 at 5:43 PM #13267Having no grounded house in 2017 it’s something awful. At least here in Italy it’s illegal too…
Electronics devices can be easly damaged whithout a proper ground. An the situation it’s even tragic when you switch off a light and an important disturb it’s eneveloped in your impiant…
Seriusly call an electrician and fix the issue as soon possible!June 16, 2017 at 8:13 AM #13272I already called an electrician, he changed all my electrical switchboard with ultra low tolerance one.
Therefore, the house is not grounded (only the switchboard).
With that new switchboard, the house doesn’t have to be grounded according to the law in France.I do not have disturb on my other electrical devices, only the OSSC.
June 16, 2017 at 9:38 AM #13273You can try to change the light switch, it should help to remove the disturb. When they are very worn they know to create high disturbs in the impiant…
June 16, 2017 at 10:17 AM #13275Does it also happen when you put the OSSC in another room? Do you have the console directly connected to the OSSC and the OSSC directly connected to the tv? Try to unplug every other device in every room, maybe some other device is interfering.
If it’s only the OSSC then maybe a different power supply will help?
June 16, 2017 at 10:48 PM #13283I lived in a brand new building before acquiring my house.
I remember that I also lost sync randomly and suspected my neighbours to turn something on or off when I was playing.
The flat was grounded for sure.So it must be either the power supply or the power strip. Right?
June 18, 2017 at 9:00 AM #13324The power surge may not only couple through ossc power supply but also affect the sync signal coming from the console. You could try powering OSSC from a 4.5V battery or dedicated UPS (if you can get one) to see if it makes a difference. In general, a device generating surges could be placed behind a noise filter (easy if it’s a single one like fridge) to prevent it affecting other sensitive devices. Alternatively, you could connect all your AV equipment to a single electricity splitter and then connect than to mains via the noise filter.
June 18, 2017 at 10:52 AM #13328Do you have a recommended noise filter Marqs?
June 18, 2017 at 10:27 PM #13336Thank you for your time.
I currently hooked everything on this https://www.pearl.fr/article/PE4458/bloc-multiprise-multimedia
The light switch is at the opposite of the same room.How can I hook up a 4.5v battery to the OSSC?
Can you link me some noise filters? I live in France and don’t really know what this is.Have a nice day
March 25, 2018 at 5:42 PM #20392Quick update on that.
I tried tu run the OSSC with an external power source (usb cable from my laptop on battery) and the issue still occurs.
I tried to hook it up on another TV, same issue.
I tried to hook my setup on another power strip, same issue.As I said earlier, I lived in a brand new grounded building and the issue also occurred.
I do not know where it comes fromMarch 28, 2018 at 9:57 AM #20459Have you tried one of those mains conditioning power strips?
March 28, 2018 at 9:07 PM #20467Do you mean something like that?
I am french and the electrical stuff does not translate very well if you’re not familiar with the subject.
