Trouble getting 1080p output with audio
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › Trouble getting 1080p output with audio
Viewing 1 post (of 1 total)
  • #12583
    SRRAE
      I got a recently got a OSSC with the audio upgrade and it’s fantastic but I need some advice getting something working.
      I have a DVI to HDMI cable which is doing wonders, but I’m struggling to get a 1080P resolution for my PAL Mega Drive.
      When I use x5 line double, the TV reports 1080P but the blacks are showing as green. If I change the output format from DVI to HDMI, the screen shows perfectly find but then there is no audio.
      Any help will be grateful.
