I’ve build for myself OSSC ver 1.8. I’ve used this firmware image for programming:
http://www.infocult.com/m/ossc/fw/v1-series/ossc_1.11-aud.jic
Programming and verification finished successfully, but there no activity from FPGA chip: RESET_N signal stays low and no activity on the I2C bus.
I’ve verified all the power rails – voltages are correct and stable, CLK signal is 27MHz 3V peak to peak. Programming and verification using USB blaster finishes with success.I’ve even downloaded image back from device after power off/on cycle and it matches original with exception of a couple of bytes at the very end of the image so expect this is some metadata specific to flashing process. Is there anything else I can check to verify what is the source of the problem? Or do I need to go in-depth and start learning how to do FPGA debugging? Any suggestions on how to solve this problem will be much appreciated.
