Troubleshootings with SFC, Neo Geo and PC Engine
NewHome Forums OSSC, OSSC Pro and DExx-vd isl OSSC – Discussion and support Troubleshootings with SFC, Neo Geo and PC Engine
Viewing 8 posts - 16 through 23 (of 23 total)
  • #9896
    arovane
      Yes it blinks but nothing happens.
      #9897
        LCD should change and give more information, you’re 100% certain this is not the case?
        #9900
        arovane
          Sorry, green light is not blinking when I press info, only remote red light does. And no nothing happens, no additional info on LCD. Other buttons on the remote work though.
          #9916
            Your remote must have one faulty button.. weird.
            #9959
            Piffles
              May I ask if you got your PC Engine from say, Doujindance?
              (As if you did there should be a switch in the back of the console to switch video mode as thats what got it working for me)
              #9971
              arovane
                No it’s a interface unit (cdrom + white pce) modified to output pure RGB. No switch.
                #9974
                  Could you try the remote programming procedure on OSSC again to get your info button to work? I would really like to know the refresh rate and information on your PC Engine. My hammerhead setup (Supergrafx and Super CD-Rom2) is working great even on a TV that’s fussy about refresh rates.
                  #9977
                  arovane
                    Ok but as you can see on my earlier message “Managed to make PC Engine work with LPF to 10MHz” so Pcengine is not a prob anymore. Neo Geo and SFC/Nesrgb are the one that are still not functionning. Have to use Framemeister with them at the moment. Will try to set the info button as you said.
