upright arcade with wells gardner 22" lcd
NewHome Forums OSSC, OSSC Pro and DExx-vd isl OSSC – Discussion and support upright arcade with wells gardner 22" lcd
  • #16075
    fitter108
      This is not a console game
      I have a streetfighter 2 CE arcade restore going on and wanted to know if a OSSC could fix my graphics problem. I now have a cga rgb to vga converter model GBS-8220 and the graphics are choppy pixelated. The monitor used is a wells gardner wgf 2258-sdbs28c with vga and dvi inputs native resolution is 1680 x 1050 16×10 ratio 30-80 khz frequency.
      I was thinking of using the vga to the input of the OSSC and then out to monitor if possible. The sound goes straight from pcb to the speakers and didnt know if that would cause a timing issue.
      Thanks for your help
      Fitter108
      #16081
        OSSC should be a good fit, of course the only way to know for sure really is to try. OSSC works in a non-stanard way so different monitors react differently. I’d be surprised if it didn’t work at all. The monitors maximum resolution isn’t a good fit for 5x mode unfortunately, but depending on its scaling other modes might work well.
        #16088
        fitter108
          Thanks so much
          #20853
          fitter108
            Just bought the ossc and will give feedback when it arrives and tested on my arcade game.
