Upscalers: How much lag is too much lag?
NewHome Forums General gaming Upscalers: How much lag is too much lag?
  • #22723
    tommytwothousand
      I’m working on a home made upscaler similar to the Retrotink 2x, except I want it to display two inputs at once in a split screen configuration. For example, I want to play SNES while a friend plays Genesis at the same time on the same TV.
      I’ve been trying to wrap my head around how to do this and realized that the refresh rate of the two inputs won’t be in sync with each other. In order to combine these I need two buffers or something and you end up with a lag of 1-2 frames just to combine them. That’s not including image processing. Assuming my understanding of all this is correct, that is. (it’s probably not).
      Anyway, I just want to get an opinion from people on how much lag (in frames) is too much lag. It looks like the Retrotink and OSCC are a frame or less, so what about say 3 frames? Right now I play all my retro games on CRTs so I haven’t got a feel for lag issues on HD screens yet.
      #22730
        Retrotink and OSSC are lag free. 3 frames is rather excessive, that’s over 48 milliseconds, plus whatever lag your TV does.
        You’d also get things like image tearing or stuttering in that kind of setup as you would have to unlock the input frame rate from the output rate. Plus how would you split? two 4:3 images don’t fit on one 16:9 display.
        Honestly, it’d be a lot less hassle to buy two TVs.
