I’m seeing the checkerboard pattern that is shown in the My Life In Gaming video that talks about the OSSC. I’m using the NTSC CSYNC Shielded/Grounded cable sold by retro_console_accessories on ebay. My SNES is the original model and pretty sure it is not a 1-chip (picture is a little soft.)
According to the video, the checkerboard pattern appears if you use composite as sync cables, but I’m using CSYNC cables, which I thought was suppose to prevent this issue with upscalers. The checkerboard doesn’t appear on my PVM. I also plugged the sync line directly into my composite video input to check, and I got a black screen. I think this confirms that this isn’t a composite as sync cable.
Anyone know why I would get the checkerboard with a CSYNC cable? Do I need a better cable? Sync Stripper? Or could the console be noisy?
Additionally, this console is a replacement I got from the Nintendo repair shop, if that makes any difference.
