V. Active 180
  • #23505
      Hi, as I know fw 0.82 is being worked on at the moment, wanted to remind you about this small fix that would help me a lot when displaying GBA in 3:2 inside a 4:3 frame on my TV.
      Which is to change the lower limit on V.Active down to 180 (currently the limit is 200). That way I can use a 240×180 active frame.
      #23518
        Sure, the lower limit can be reduced. 480×360 and 240×360 presets for GBI are included in v0.82 as well.
        #23520
          Thanks a bunch!
