Very quiet audio input from mini-jack (fixed)
NewHome Forums OSSC, OSSC Pro and DExx-vd isl OSSC – Discussion and support Very quiet audio input from mini-jack (fixed)
  • #13269
    SRRAE
      Hello,
      Is anyone else getting very quiet sound when inputting the stereo RCA into the minijack?
      SCART sound is great and my TV/Monitor volume is at the same level I use it for watching TV or playing other consoles which is at level 10 or so.
      However playing something like my Dreamcast via the VGA and audio in, or OXB via Component and audio in, the volume is at full volume (100) and its an ok level.
      Is this how it is or is something wrong?
      #13270
        It should work better if you unplug the scart cable when using the audio jack as input.
        #13271
        SRRAE
          Yeah that worked 😀
          I didn’t need to unplug it, just turn off my scart switch did it.
