VGA from Trident 9000 cut off
  • #22117
    root42
      I have just received my OSSC and have hooked it up to my retro rig: 286 with TVGA 9000. The OSSC feeds into an HDMI grabber which in turn feeds OBS.
      The test pattern looks good and centered, see this screenshot:
      test pattern
      However when I switch to AV3/RGBHV I get 449p, 31.83kHz 70.91Hz and the image is cut off:
      BIOS display is cut off
      So I think the image needs to be tweaked to be centered. How do I do this?
      More images here:
      Screenshots of BIOS and DIAG on my 286 through OSSC
      #22120
      paulb_nl
        You can tweak the image with the Advanced timing tweaker in Sampling opt: http://junkerhq.net/xrgb/index.php?title=OSSC#Advanced_timing_tweaker
        H.backporch & V.backporch affect horizontal/vertical position. H.active & V.active affect size/cropping.
        However you should update to firmware 0.81 which added a 640×400 preset that should already have the correct settings.
        BTW the black looks crushed in the test pattern. You should select Full Range at Video recording device settings and try other video formats like XRGB.
        #22132
        root42
          Good to know! I will update the firmware. Currently at 0.78a as it was shipped.
          Yeah, I played a bit with the OBS settings, since my VGA output has the black a bit bright. But I will test how to get a decent dynamic range.
          #22145
          root42
            Ok, I upgraded to 0.81 and the image is a bit better. However it is still shifted and cut off.
            I tried fiddling with the advanced timings, but I only managed to get it barely correct.
            Is there any guide to this? Am I missing something?
            #22149
            paulb_nl
              Does it show correctly when connected to a monitor instead of the capture device?
              FirebrandX made a video where he shows shifting the image at 3:24 https://youtu.be/dEr3uFPs7gU?t=3m24s
              Its basically just changing H.synclen or H.backporch.
              If that does not work with your capture device you can try to set 384p to Passthrough so the capture device receives 640×400 instead of 1280×800.
              #22154
              root42
                Yes, image is fine on my LCD screen.
                I managed to center and size the image now. I will post the parameters later, for documentation.
