VHS & LD blacking out
NewHome Forums RetroTink Products VHS & LD blacking out
  • #41829
    Patrik Bergstrom
      When using a VHS player connected through the RetroTINK 2X Pro, the picture blacks out when there’s too much noise. It also blacks out when fast-forwarding, both on VHS and LaserDisc. Other cheaper converters don’t do this. What is the cause of this and do the RetroTINK Mini & Multiformat act the same way? It’s a shame because apart from this it works great with VHS & LD.
      #42112
        Yeah unfortunately VHS is a bit of an oddball signal and difficult to deal with. RetroTINK products aren’t really designed with VHS or laserdisc in mind.
        #42115
        Patrik Bergstrom
          I know, but what is the actual reason for RetroTINK having more troubles with this than other converters? Is it because it doesn’t scale the video?
          #42137
            Other converters do struggle, you could try coupling it with an external time base corrector.
            #42138
              Mike goes into some more detail on this video that you might find useful – https://www.youtube.com/watch?v=D_uYu5XKo0U
