Videopac G7400 50Hz – converting to 60Hz?
NewHome Forums OSSC, OSSC Pro and DExx-vd isl OSSC – Discussion and support Videopac G7400 50Hz – converting to 60Hz?
  • #16925
    grips03
      I have Videopac G7400 (RGB PAL 50Hz) connected to OSSC, then HDMI to Sony (NTSC 60Hz) TV. TV says signal not supported using OSSC*. Anyway for the OSSC to change 50Hz from the console to 60Hz so picture will display on my TV?
      I have another converter that supports this, however the picture quality is not as good as OSSC 4x mode looks better than the other converter. The other converter doesn’t really have a model number. Its a small 4″x4″x1″ metal box labeled “HD Video Converter”. My hope was that OSSC would have this feature.
      *My XRGB2 does this as well.
      #17029
      grips03
        Added to feature request page. Hopefully this can happen as it would allow Videopac+ G7400 Euro only console to work on NTSC TVs using OSSC.
        #17033
          The OSSC and XRGBs are different machines for different applications. While both are intended to digitize analogue AV signals, the XRGB machines are full scalers, in that they can scale and shape the image to your preference, at the cost of video lag; whereas the OSSC is a line doubler, which can enlarge the image and tweak certain characteristics with imperceptible lag.
          Ultimately, you will need either an external converter (like this) or track down a TV that supports 50Hz video. (A bit of a pain in North America, but not impossible.)
