Visual “static” on OSSC video output (N64 RGB)?
NewHome Forums OSSC, OSSC Pro and DExx-vd isl OSSC – Discussion and support Visual “static” on OSSC video output (N64 RGB)?
  • #52501
    Dusclops_
      I’m getting a visual noise that almost looks like CRT static with my OSSC. It’s mainly noticeable on still screens (for example after pausing in Super Mario 64). It’s only visible on the actual display, not from my capture card footage.
      I’ve tried both generic and optimized settings and it’s still present regardless. I am using high quality cables from Retrovision.
      I’ve tried to record the issue with my phone, hopefully you can see what I mean (it’s much more noticeable in person): https://streamable.com/1s9gui
      Any ideas on what the issue could be?
      #52515
        What kind of display is it you are using?
        #52525
        Dusclops_
          A 1080p IPS monitor, specifically a BenQ MOBIUZ EX2510.
          #52535
            Same effect at all multiplication modes?, does it appear on the test screen?
            #52571
            Dusclops_
              Yeah, the video I recorded was at Line4X but it’s also visible on the other modes.
              The test screen doesn’t have the static, at least not from what I can see.
              #52680
              Dusclops_
                I looked a bit more into this topic and some people said that the visual noise/static is normal in some N64 games?
                Can anyone confirm/deny this?
                #52687
                  Possibly, I mean there’s no such thing as “perfect” analogue RGB, what kind of RGB mod do you have?
                  #52761
                  Dusclops_
                    It’s Tim Worthington’s N64RGB with de-blur. The noise only seems to appear with certain backgrounds in certain games, and if I disable the game’s anti-aliasing via a patch it disappears completely. I guess I’ll dismiss it as normal for now unless someone says otherwise. It’s not too noticeable in any case and doesn’t seem to appear with other consoles (although N64 is the only 240p console I’ve tried so far).
