Voultar MD1 RGB Bypass on VA4
NewHome Forums Repairs and Upgrades Voultar MD1 RGB Bypass on VA4
Viewing 2 posts - 16 through 17 (of 17 total)
  • #27192
    BlueStinger
      Hi hardyhell, try using shielded wires instead : https://twitter.com/Consoles4You/status/1155622288684961792
      #42372
      Mr.Ash
        Today I successfully performed the RBG Bypass Mod on my PAL Megadrive (Mainboard Revision VA4). As basis for this I used the manual on this page .
        The reason for the installation was, because my aging Mega Drive showed clearly visible jailbars, which did not disappear completely even with a professional RGB cable . With the installation of the RGB Bypass from Voultar I hoped to solve this permanent problem and to get a nicer RGB image on the side.
        However, I am rather disappointed with the result, especially since it is not a simple mod. The improvements of the RGB image are minimal, and the jailbars did not disappear completely. The effort was hardly worth it for me. So I think that the installation of a RGB bypass is only worthwhile if the original RGB image output is really bad and no high quality RGB cable can help anymore.
