[SOLVED] Voultar RGB Bypass issue on Megadrive V04 PAL
NewHome Forums Repairs and Upgrades [SOLVED] Voultar RGB Bypass issue on Megadrive V04 PAL
  • #44941
    Karim El Housni
      Hello,
      I installed the Voultar RGB Bypass V2 today but it is not working properly. No sync.
      I have try to redo my solderinig job multiple time but not working.
      i use a RGB SCART PACKAPUNCH PRO CABLE.
      So anyone can help, it will be very much appreciated.
      Thanks in advance !
      #44978
      Karim El Housni
        Solved.
        The CSYNC from PIN10 was not going properly to the 8-Pin DIN U. I just add a cable directly between both and it work.
        #44993
          Glad you got it sorted!
