Weird issue with 384×240 at 5x
NewHome Forums OSSC, OSSC Pro and DExx-vd isl OSSC – Discussion and support Weird issue with 384×240 at 5x
  • #64371
    Razile
      Hi, i have a weird issue with my ossc, i cant get an image at 5x while in 384 optimized mode, i get the following image and the wrong resoluition of 1922×1080.
      Btw the image is frozen, even if the game in background is playing.
      I tought the issue was my i.6 modded ossc by i have borrowed a kaiko 1.8 and the issue persists…
      all other modes work, even 6x! Also if i set 5x mode to 1600×1200 5x works…1920×1200 also doesnt work.
      Thanks in advance for any help fixing this.
      #64499
        Any chance to try another display? Sounds like a compatibility issue with the existing one.
        #64562
        Razile
          Hey, thanks for checking my issue, sadly this is the only display i own that is larger than 1922×1080… but so it is normal that the ossc outputs a 1922×1080 image? cant it crop it to 1920 like it does with the vertical resolution?
          Happy new year!
          #64571
            Most likely the display just misinterprets active width due to non-standard overall timings. That was the reason I asked to check with another one.
            #64573
            Razile
              I’ll try to borrow another monitor, thanks for now!
