Which PS2 SCART cable do I need?
NewHome Forums OSSC, OSSC Pro and DExx-vd isl OSSC – Discussion and support Which PS2 SCART cable do I need?
  • #9642
    Maverick
      Received a email today with the opportunity to jump in on the current batch, so I placed my order, and now I wait. LUCKY!
      On to my question, I need to figure out which SCART cable I need. I have a US NTSC PS2 v14 and I want to use it in RGB mode. I’m currently looking at these two cables, but I’m unsure which one to purchase.
      Sync-on-Luma
      http://www.ebay.com/itm/201402911327
      Csync
      http://www.ebay.com/itm//162220135606
      Note: I have a DMS 4 Pro SE modchip with Toxic OS installed on the chip, though I don’t think that matters, but I figured I should mention it just in case.
      #9657
        Either cable should work but I’d tend to go for sync on Luma, shouldn’t make a difference to OSSC but as long as you don’t want to ever use composite video (why would you?) it makes sense to go for that cable.
        #9671
        Maverick
          I don’t plan on ever using composite, so I went for the Sync-on-Luma cable. 🙂
          Thank you
