Wrong aspect ratio 3x and 5x on 4k panel
NewHome Forums OSSC, OSSC Pro and DExx-vd isl OSSC – Discussion and support Wrong aspect ratio 3x and 5x on 4k panel
  • #27514
    nullifer
      Hello,
      On my OSSC the aspect ratio is wrrong on 3x and 5x with my 4k panel
      (240p) I’ve tried changing widescreen and 4:3 setting. (obviously 1:1 works correctly but not scaled big enough)
      I’ve tried manipulating the other options but it’s always slightly stretched or too squared. or for example on 1920×1080 setting for 5x it is correct ratio with widescreen, but the image is cropped.
      anyone know how to fix this?
      #27517
      nullifer
        OK 3x mode works correctly with my monitor set to widescreen, but 5x still can not get the correct aspect ratio
        #27523
          1920×1080 in 5x mode will always be cropped as it can’t fit otherwise.
          #27532
            Since you have a 4k panel, you can probably use the 1920×1200 or 1600×1200 setting and get that decently scaled. Note that for compatibility reasons, x5 mode is slightly too wide. This can be corrected by lowering h.samplerate to 1950.
