Bliss-Box Bridge Cable
Bliss-Box Bridge cables have arrived at VideoGamePerfection.com. These cables allow you to connect the Bliss-Box Bridge and then the Gamer Pro/Gamer Pro Advance adapters to your classic consoles, allowing you to make full use of your classic controllers across your entire collection.
Love N64 but hate the controller or the analogue stick? No problem! Now you can play Super Mario 64 with a PS2 analogue controller. Want to use your PS1 or PS2 arcade stick with the Saturn?, now you can. Want you use the Saturn pad for a shmup on the PS1, that’s possible too. Want to use 8BitDo wireless SNES pads on your 100% original hardware NES?, you can do that too. There are literally hundreds of different combinations. Never be stuck using a controller you do not like again.
You can buy the Bridge itself by clicking here. Use the links below to purchase a cable for the following classic consoles:-
Bliss-Box Bridge NES cable
Bliss-Box Bridge SNES cable
Bliss-Box Bridge N64 cable
Bliss-Box Bridge GameCube
Bliss-Box Bridge PlayStation 1 & 2 cable
Bliss-Box Bridge Saturn cable
Bliss-Box Bridge Wii cable
View our entire range of Bliss-Box products by clicking here.
