Introducing OSSC 1.8
OSSC 1.7 is no more, please welcome OSSC 1.8! I know we said that OSSC 1.7 would probably be the last hardware revision of the classic OSSC design but it turns out that Markus was able to squeeze a little more out of the design with some very minor changes.
So what is new this time? OSSC 1.8 has improved power/ground supply distribution with a new 4-layer PCB. Of course, the over voltage protection, improved audio toggle switch and reduced temperature and power consumption the OSSC 1.7 introduced have also been carried over to OSSC 1.8. This new revision OSSC can also natively run the new 1.xx firmware branch, with the latest firmware version being 1.06 at the time of writing. Read on to find out what’s new in firmware 1.06.
Firmware 1.06 introduces the following new features:-
Improved sync handling – Sync dropouts with sources such as PC and arcade hardware should be vastly reduced thanks to this new firmware revision. Users are already reporting stability improvements with previously troublesome hardware such as retro PCs.
HDR mode – Turn on your TVs HDR mode for improved brightness. Note that turning on HDR mode will affect colour and gamma accuracy and may require recalibration.
6X output mode – Convert 240p to 1440p (with pixel repetition). A compatible TV/monitor is required.
Shadow mask emulation/post processing filters – Mimic the look of a classic CRT even more closely. Works best at high multiplication modes (5x or 6x).
Some of the cool new options available in the new OSSC 1.xx firmware
Using the new firmware on older OSSCs
If you have a previous revision OSSC then don’t worry, you can still use the new firmware, all that is required is a small hardware modification. Obviously, you won’t magically gain new hardware features such as the new PCB, or over voltage protection on OSSC 1.6 or earlier, but you can still use the new firmware and gain the new sync handling improvements and other new features. Details of how to carry out this mod are available here.
If you’re not confident with doing the task yourself, we now offer an at-cost upgrade service through our partners BetaGamma computing. Any OSSC purchased from VGP or classicgamestore.ch is eligible for this service. Click here to purchase this service.
If you have a clone or competitor OSSC then the upgrade may still work, depending on whether the competitor followed the original specifications or not. Many of the companies who produced cheap clones of the OSSC cut corners or used substitute parts for the memory chips which may mean upgrading to this new firmware is not possible.
Manufacturing on OSSC 1.8 has already started, and units will be available in mid/late October 2023. The price is expected to be €115 for the base unit, with the option to buy with or without power supply and/or remote, as per usual. Stock will be plentiful, there is no need to worry about pre-ordering. We will announce on all our social media channels as soon as it goes on sale. |
It would be a really good deal for me once it gets S-video support. Hopefully it’s compatible with the 4K Gamer Pro which only accepts a proper 1080p input.
Very nice! Will the OSSC Pro have a full 4:4:4 processing pipeline, and at 1440p no less?
