Reply To: Simplest way to connect different sources from an Extron?
NewHome Forums OSSC, OSSC Pro and DExx-vd isl OSSC – Discussion and support Simplest way to connect different sources from an Extron? Reply To: Simplest way to connect different sources from an Extron?
#22261
NYI
    Thanks for your help! I agree – the BNC to VGA, and then simply using the BNC to RCA adapters works perfectly and is less expensive than buying a BNC to Scart cable with a resistor, and avoids having to use another output from the Extron just for component sources.
