100 hz Sony CRT via OSSC Pro?
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › 100 hz Sony CRT via OSSC Pro?
- This topic has 5 replies, 4 voices, and was last updated November 11, 2026 at 10:51 PM by
marqs.
November 3, 2026 at 1:19 PM #71132
Hello,
i will write short, what I want…
I use the OSSC Pro with AV-Extension and AV-Adapter to transform the NTSC signal (59.94hz) from mini PC to my 100hz / 120hz CRT… (PC->HDMI->OSSC-Pro->VGA->SCART->CRT)!Everything is ok, signal is there, i use the LM-A Mode to drop my 720p lines of mini pc to 240p / 480i to my CRT (720p -> Line-Dropping -> 240p / 480i). I use the full RGB colorspace, to get a sharp picture via RGB-SCART of my CRT….
BUT:
For example N64-Games everything seems to be ok, seems! Straight vertical scrolling you see on 480i are not smooth, but maybe i can accept that…
In SNES-Games with 240p you see even more problems… it’s easy to see disturbed scrolling and some ghosting, for example in Super Mario World on “?-Boxes” and so one…I know, it’s more or less a problem with 100 / 120 hz processing of the TV… ok… but i want to use this thread to get tricks and tweaks, that the problems become smaller…
Do you know websites or own tweaks to get a smooth picture scrolling for 60 hz games in 240p / 480i ?
My own tweaks are followed:
– use the service menue:
to activate the VCO with NTSC protocoll (nice tweak, my own find!),
to deactive SVM or VM
– use the software of PC:
to activate VSYNC, VSYNC-Swap-Intervall = 1 in RetroArch (emulator),
to deactivate threaded video,
to activate VSYNC generally in graphic driverThese tricks are great, but even thought you see ghosting in scrolling and dancing crawls in scrolling for 240p in 120 hz… the main problem seems to be the TV itselfs, the Sony Trinitron KV36-FS-70 in DRC100-mode… i want use 120 hz mode implicit because no flicker and you see scan-lines…
There’re a nice guy outside, who can help me to fix the problem with such kind of TVs?
November 3, 2026 at 9:18 PM #71136Obviously it’s a way for OSSC Pro to set the same HsyncLen and VsyncLen to same amount like the actual HDMI-source!
In my case
720p -> 240p/480i : HsyncLen = 40 , VsyncLen = 5To center the picture, you have to increase the backporch for H and V!
This reply was modified 3 weeks, 1 day ago by
Kekstier.
November 10, 2026 at 7:26 PM #71263Most likely your PC is doing some scaling of its own, probably non integer, to get the N64 game to 720p. OSSC can’t correct for this.
November 11, 2026 at 2:45 AM #71269The main problem is the tv itselfs… there’re some tricks (see above!) to weaken this issue but 100% sync scrolling is only possible in 50 / 60 hz mode, which supports my 100 hz sony but then without scan-lines (or scan-line gaps)…
Maybe some one, who read this thread, has a “golden trick” to improve the scrolling for 60 hz sources to a 100 hz / 120 hz TV, so my hope!
November 11, 2026 at 1:47 PM #71276I don’t know if the model in question has motion interpolation as part of its DRC processing, but if it does that may be the culprit.
Motion compensated frame interpolation is quite unpredictable. It breaks the picture down into blocks and compares those with the most similar parts of a previous frame or field, then moves them to what it guesses is the midpoint to create an intermediate frame. For each block it searches the surrounding area in the previous frame for a handful of candidates. Whichever is the most similar then gets compared more precisely to the previous frame find the best matching position. The resulting motion vector is then used to move things around and also to narrow down the direction and area for the search in the next frame.
When things move past each other, in or out from the edges of the picture, at an irregular speed, suddenly change direction, move very fast, or when there’s a cut or fade between camera angles, the processing fails to determine motion properly. The intermediate picture will then be distorted. That problem is hard to crack and still persistent in modern TVs, 30 years after the technology first popped up on the consumer market, but the early generations of it split the picture into pretty large blocks and had simpler matching algorithms.
So, the only way to avoid the problem might be to turn off the motion compensation processing if possible. You will get a more flickery picture, but it should be consistent.
It could also be that the set de-interlaces the picture so it can be output as progressive at 50/60 Hz or re-interlaced at 100/120 Hz.
November 11, 2026 at 10:51 PM #71286Yeah, 100/120Hz TVs are not good reference points due to many ways they may degrade picture/motion. Some of them can be modded for 31kHz/60Hz progressive scan to bypass all digital processing, but I think all Sonys use their own branded chips which are undocumented for the most part.
