Add RGB range (limited/full) output option
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Feature Requests › Add RGB range (limited/full) output option
  • #25058
    SirRockALot
      This is surprisingly absent from the OSSC. It seems like virtually every HDMI console supports both, the only exceptions I can see is that the Wii U only does limited while the OSSC only does full. Many people have displays / setups with flaky range autodetect and chose to just go all-limited for maximum compatibility.
      I’d assume scaling and offsetting the OSSC’s full range to limited would be relatively easy in terms of implementation effort and runtime cost and this feature would help integrating the OSSC in certain setups. An option for RGB range would be much appreciated.
      #25071
        A recent test firmware has an option for YCbCr444 output (under TX mode) which is unambigious regarding color coding range (aside from xvYCC). That can be used with displays that are unable to decode RGB quantization flag embedded in HDMI signal.
        #25073
        SirRockALot
          Oh, neat. Guess that avoids the issue entirely. Thanks!
          Unfortunate that so many displays seem to have an issue with handling this automatically. My old TV did it just fine. I can only assume that some popular device specified the format wrong and display manufacturers started ignoring it.
          #25128
          drojman
            That firmware update works great for me. I was getting severely crushed blacks without it, I think due to my monitor. Will it introduce any issues using it in that mode?
            Thanks.
