Amstrad CPC, OSSC and BenQ BL912
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › Amstrad CPC, OSSC and BenQ BL912
  • #25196
    monkat
      I’m trying to get my amstrad to work with the BenQ 912 monitor.
      If I connect it via hdmi (and ossc) to my samsung tv it works fine.
      If I cannect it via a hdmi to dvi adapter to my Benq 912 I get a blank screen.
      I’m a newbie with the OSSC so if any help could be given to get this working I’d be grateful.
      Setup is: Amstrad cpc via Scart to OSSC to hdmi to hdmi adapter to Benq BL912.
      Thanks!
      #25197
        Could be one of a number of things.
        First thing, though; what kind of video mode is the OSSC outputting, and does your monitor actually support it? From what little I understand of the Amstrad, it outputs at or about 50Hz, which the OSSC won’t modify; and what documentation I found for the BenQ BL912 (the resolution document, specifically) suggests that it doesn’t support 50Hz.
        If your monitor does support 50Hz, then I would think that the output of the Amstrad is too off-spec for the monitor. What does the LCD on the OSSC report when your Amstrad is powered on?
