Any simple Composite->VGA solutions?
NewHome Forums General gaming Any simple Composite->VGA solutions?
  • #34567
    Anonymous
      Is there a simple 240p composite -> 31khz VGA solution ala RT2x?
      I’ve seen stuff like Garo or GBS, but they are 1:1 input-output and/or SCART_RGB/Component only.
      PS: Is there a solution for composite 240p -> SCART_RGB/Component?
      #34570
        Pretty much everything left on the market outputs HDMI these days. There’s the Koryuu that’s out soon (https://videogameperfection.com/2019/11/25/koryuu-is-go/) that outputs component video.
        #34571
        Anonymous
          Thanks, I forgot about Koryuu.
          I think I’ll just go RT2x->HDMItoVGA converter, do you know if these devices add any lag? And should RT2x be in 2x or passthru mode for these converters?
          #35075
            Some add lag, most don’t. As for what mode, it would really depend on what you were feeding into the RetroTINK and what display you were outputting to.
