Anyone want to dump their programmed L336 remote flash chip? (raspberry pi)
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – DIY & Repair Support › Anyone want to dump their programmed L336 remote flash chip? (raspberry pi)
- This topic has 7 replies, 3 voices, and was last updated May 2, 2017 at 5:10 PM by
Quantumcross.
April 14, 2017 at 4:25 AM #12389
I am doing the DIY kit, and I realized that I have no way to get the IR codes onto my L336 remote that I ordered from aliexpress. I cracked it open and lo and behold it’s just a simple I2C flash chip.
I have managed to dump the chip using a raspberry pi and a SOIC-8 test clip.
If someone would be so kind as to dump their flash chip, I would greatly appreciate it. Additionally, it would be a great asset to have as a download for those who are technically inclined to program their own remote.
If anyone is willing and has the equipment (raspberry pi and some way to hook 4 wires to a SOIC-8 chip, solder or clip), I can provide instructions on how to do so.
April 17, 2017 at 9:26 PM #12442Once I got my OSSC running I can help you with that. I got an old raspberry pi model B. Finding proper clips or soldering wires should not be a problem.
April 17, 2017 at 11:50 PM #12446Awesome!!! I’ll post some instructions later tonight.
April 20, 2017 at 5:25 AM #12503OK sorry for the delay in these instructions.
- Remove remote batteries
- Use some kind of spudger or plastic tool to go around the edge and open the remote (all plastic clips, careful not to break them)
- There are 2 chips, locate the flash, it should be a 24C16N (If it’s not a 16 we can probably still dump it just different command)
- Take your pi, turn on the i2c bus in
sudo rasbpi-config, reboot. - Get the i2c tools:
sudo apt-get install i2c-tools - Pinout is:
- 4 – GND
- 5 – SDA
- 6 – SCL
- 8 VCC
- Hook up 4 wires to pi with a clip or by solder
- pi pinout: https://pinout.xyz/
- pin 1 is 3.3V, pin 3 is SDA, pin 5 is SCL, pin 6 is GND on pi
- run
sudo i2cdetect -y 0, you should see addresses 50 through 57 light up in the output. - dump the flash:
for i in 50 51 52 53 54 55 56 57; do sudo ./eeprog /dev/i2c-0 0x$i -r 0:256 -f -o 0x$i-2.bin; done - zip up all the
0x5*.binfiles, upload em somewhere, and I’ll let you know if it works!
Edit: Here’s a datasheet: http://pdf1.alldatasheet.com/datasheet-pdf/view/175224/ATMEL/AT24C16N-10SA-2.7C.html
April 20, 2017 at 11:54 PM #12523That seems like a round about way to do it? Have you tried just trying to sync your remote to the OSSC?
Just hold down Button 1 (the one closest to the LCD) on your OSSC as you turn on the power, you LCD will then give you instructions on which button to press, I synced my Yamaha receiver remote without any problems.EDIT:
Also you can try the automated programming for brands etc of the remote, the OSSC uses NEC standard AFAIK
http://codesforuniversalremotes.com/program-chunghop-universal-remote-control/April 21, 2017 at 5:18 AM #12528Maybe that will work then, I don’t have my OSSC complete yet. I just got the HDMI chip today, just waiting on the cyclone… Then I will be able to mess around with it. It was fun to screw around with the remote while I’m anxiously waiting 🙂
April 21, 2017 at 11:03 AM #12532Ah yeah =D just got mine up and running a few days ago 😛
May 2, 2017 at 5:10 PM #12700Ok, my Cyclone finally came in and I completed my OSSC. After spending an hour trying to find a basically invisible short on one of the 3.3v lines (thanks for the pictures of the PCB traces, they were very helpful!!!), my OSSC is working great!
I’ve now realized how stupidly easy it is to program the OSSC to the remote, so you’re right, this is basically useless! I just used my tv remote to find a code set that the OSSC responds to, then I used that to program my L336 remote button by button.
