Audio issues with HDMI to VGA adapter
NewHome Forums OSSC, OSSC Pro and DExx-vd isl OSSC – Discussion and support Audio issues with HDMI to VGA adapter
  • #21321
    SamuelHan
      Hello guys,
      I’m using an OSSC 1.06 with firmware 0.78a for nearly a year now and I’m totally satisfied with it so I would first thank you for your hard work !
      Unfortunately for me I’m using a Sony W705 series as main TV, so the magic device can’t go full power and I was looking for an alternate solution, so I’ve decided to use and old lcd monitor with only VGA and DVI connections.
      I’ve no problem with video, as I can reach line 4x with no problems but the audio is buggy.
      I’ve tested two configurations, first a Neo Geo AES with a packapunch scart cable with a jack for stéréo and there is no audio, a second with a pc engine scart cable ( I have also a packapunch csync cable but the OSSC doesn’t seems to like it) and the sound is awful (cracks and parasites).
      I try to hook a ps3 to the converter with the same HDMI cable and I don’t have any audio issue.
      I’ve searched over the web during a couple of hours but no one seems to have the problem, so maybe i’m doing something wrong.
      Thanks in advance for your answers.
      #21353
        DVI monitors often have limited or no support for audio at all, that’s probably the case here unfortunately.
        #21358
        SamuelHan
          Hello,
          Thanks for your answer but if the problem come from the monitor, how can you explain the fact that when I hook a ps3 to the same monitor, with the same adapter and hdmi cable I don’t have any audio problem ?
          To be sure I also hook a dreamcast directly in VGA and no problem with audio so far.
