Audio issues with SCART with the Turbografx 16
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › Audio issues with SCART with the Turbografx 16
  • #39300
    Dustin
      I have just received a Genesis Model 2 SCART cable from Retro Access:
      Genesis 2 32X/CDX RGB SCART cable with csync
      and the DB Grafx Booster TTP from Castlemania Games:
      db GrafxBooster TTP
      and I am having some issues with the audio. The picture is amazing but the audio is only coming out of the right speaker and is EXTREMELY quiet and muffled sounding. I have the current firmware installed (0.86 with audio) and I have used the OSSC with the Wii component with the 3.5 mm jack and that all worked well. I have tested the Turbografx with the OSSC on another monitor with the same results as well. Does anyone have any insight to what the problem is? Thank you.
      #39367
      Dustin
        Ok, I have solved the issue and posting in case someone else comes across the problem. I have disconnected and re connected the GrafxBooster several times but I must have not connected them to the correct pins or it wasn’t secure enough. Either way, I re-adjusted it and video and sound work perfectly now.
