I finally got around to testing my OSSC with my Nintendo Wii with Component Cables + RCA to Auxiliary for sound. To my horrible realization, my unit seems to be processing audio only through the left channel. I’m using an RCA to 3.5mm adapter to connect to the port left of the HDMI connector. I’ve also tested this port with a seperate auxiliary cable directly to my phone, with the same result. I can confirm it’s not my cables (I tested both cables directly to my speaker, and they work fine). I’ve also tried toggling the tiny switch + testing the other auxiliary port – no sound comes through at all upon doing this.
Is there something I’m missing? Or did my unit ship damaged? If it’s the latter, I’m not sure what to do as I stupidly didn’t test this until now (my unit shipped last December). 🙁
