Audio selection on OSSC
- This topic has 1 reply, 2 voices, and was last updated June 14, 2019 at 4:56 PM by .
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › Audio selection on OSSC
How do you select the audio input? I have consoles plugged into the SCART(PC Engine) and the YPBPR jack and audio on audio 2. I can’t seem to get audio out of the scart unless I disconnect the audio 2 input, and I can’t get audio out of the YPBPR regardless. Is this something I do on the remote?
There’s a small switch next to the audio jack that you need to flick. It determines if the jack functions as AV1 output or AV2 input. I recommend using a paper clip to reach it easier.
