AV1 Sync Issues
  • #23051
    vwpunk
      Hi Everyone,
      I’ve had my OSSC for just over a year and have had no problems whatsoever… until today!
      All consoles and connections I’ve tried through AV1 Scart are not being recognised at all. I currently have a Mega drive, Saturn and SNES all hooked up via a HAMA switch box to the OSSC which has been working flawlessly until now. I’ve tried all combinations of all consoles direct into the OSSC and through the switchbox, but to no avail. i.e. red light on OSSC “no sync” displayed on screen
      The consoles work when connected directly to the TV via RGB Scart, and AV2 and AV3 on the OSSC are working fine with my other consoles.
      I’ve tried power cycling and resetting the OSSC but nothing is working.
      Does anyone have any ideas/advice?
      Thanks for your help
      #23054
        are the other inputs still working?
        #23055
        vwpunk
          Yes, I’ve got a dreamcast in AV3, and a PS2 in AV2 and both are working absolutely fine
          #23063
            Well that was unexpected….
            I can only think maybe the SCART socket itself is damaged then. Unfortunately you would need to send your unit in for servicing in that case.
