Beginner Question – Gamecube through OSSC
NewHome Forums OSSC, OSSC Pro and DExx-vd isl OSSC – Discussion and support Beginner Question – Gamecube through OSSC
  • #35497
    GrahamC
      Hi folks,
      Beginner here with a beginner question! Very grateful if anyone can advise.
      I have been using a Megadrive through the OSSC (Scart cable) and works wonderfully, no problems.
      I’m now trying to connect my Gamecube. I have the standard AVI component cable with the GC (outputs to red, white, yellow)
      I’ve tried plugging the AVI component into a scart adapter (just a straight adapter), then plugging the scart into the OSSC (pictured AV1). The sound gets through but no visuals.
      Am I correct in assuming that I need a composite or RGB cable ‘out’ from the Gamecube to use with the OSSC? I’ve copied in images below from the user manual for reference.
      OSSC1
      Many thanks in advance!
      #35510
        No, you need a component or RGB cable, OSSC does not support composite video (unless you use a transcoder/converter like the Koryuu)
        #35526
        GrahamC
          Thank you very much (as you can tell I get confused between ‘component’ and ‘composite’!)
          Would something like this be suitable? Packapunch Pro RGB
          #35530
            Yes although keep in mind you would be limited to 480i with that. For 480p, try something like the GCHD adapters https://videogameperfection.com/products/gchd-mk-ii-hdmi-hd-adapter-for-gamecube/
            You also need compatible software (NTSC versions of games or homebrew like Swiss) to access 480p mode in Gamecube titles.
            #35555
            GrahamC
              OK thanks – I think that is probably a bit too expensive for me (especially as I already spent quite a lot on the OSSC itself!)
              I’m hoping the RGB + OSSC should at least make an improvement over standard composite cable (yellow, white and red) being plugged directly into my HD-TV.
              Many thanks again for the help, really appreciated!
              #35563
                Oh yes the RGB cable will be quite a bit better than just composite.
                #35565
                  Not sure what territory you are in, but RGB out only exists on PAL Gamecubes, just so you know.
                  #35567
                    Oh yes that’s true, totally forgot about that.
                    #35579
                    GrahamC
                      I am in a PAL location and only have a PAL gamecube and games.
                      Many thanks for the replies guys – really appreciated!
