Best N64 settings?
  • #25970
    ENunn
      Been trying to get the best settings for my N64. Some games look really crisp but some other games look too pixelated.
      So the settings I tried was H.samplerate 387, H.synclen 22, H.backporch 34.
      The text in some games (like Supercross 2000) is pixelated.
      I have a 512×240 optimized profile for the PS1 and it looks much cleaner.
      Any way to fix it or am I just out of luck?
      #25979
      paulb_nl
        Some games use 640×240 resolution so for those you would need to use 512×240 optimized with H.samplerate 773 and H.active 640
        #26100
        ENunn
          sorry that im a week or two late lol
          everything looks fine now! thanks!
          #26256
          ENunn
            Sorry for bumping but I’m having a bit of a problem for 320×240 games. Half of the screen is quite sharp yet the other has a bit of noise.
            Look at the text. There’s a little noise on the side.
            My settings for 320×240 games are this:
            H. Samplerate – 387
            H. synclen – 22
            H. backporch – 34
            H. active – 320
            Sampling Phase – 22 deg
            Any help? Thanks!
            #26577
            paulb_nl
              With the new firmware 0.83 you should be able to correct this with H.samplerate 386 and H. s.rate adj 3 or 4.
              #26814
              ENunn
                i’m a few weeks late since i just found my n64 after moving
                its still a bit noisy but setting the h samplerate to 386 with the H. s.rate adj set to 1 was the “sharpest”. 2 3 and 4 added noise. not sure what im doing wrong but it could be the n64’s blur as far as i know 😛
                edit: changing sampling phase to 281 and changing h s rate adj to 3 seems to mostly fix it although there might still be a bit of noise and yada yada
                #26849
                paulb_nl
                  Looks like you’re having slow transition issues. Both sides of the letters have an equal shadow so the sampling is correct.
                  Try to disable Video LPF (not Sync LPF) and tweaking sampling phase. I’m guessing you have a N64 modded with a 7314 amp which has an LPF so it could caused by having both LPF enabled.
                  BTW you should tweak the R/G/B gains because the white background is a bit dark. The white color here should be around 248.
                  EDIT: Here’s the result I get with a 7314 amp, Video LPF off and Luma sync cable
                  #26858
                  ENunn
                    yeah i’m using the 7314 mod
                    looks like i got it. thanks man!
                    #47934
                    Venus
                      Hello guys!
                      First my English is not the best, i am from austria. I hope you understand me and can help me out.
                      I had my NUS-001 (EUR) N64 console RGB modded and bought an ossc. I connected the N64 with an RGB scart cable to AV1 at the ossc and only get a black picture where after a few seconds the game picture briefly flickers and then immediately turns black again. it repeats itself over and over again. i pressed the red button 1 on the remote control, which i think is correct. Can someone please help me get this to work? I updated the firmware to the current one.
                      Please help 🙂
                      #47943
                        Which RGB mod did you install? If it was e.g Borti’s, are you sure you configured the jumpers correctly for your cable?
