Best settings for Wii?
  • #11296
    Anonymous
      My setup:
      – PAL-Wii (first version with GameCube ports; I also tried the later version without the GC ports)
      – Orignal Nintendo Wii Component cable
      I can’t seem to get a decent picture from the console in 480p, as the horizontal axis is extremely unsharp. Playing with the usual settings (Video LPF, Sampling phase) doesn’t help.
      I know that the Wii is infamous for its lackluster signal quality, yet I wonder… did anybody manage to get a decent picuture from the console?
      And if you did – how did you do that?
      #11309
      paulb_nl
        I doubt you can get a good picture out of the Wii with its blurry output. Make sure the 480p sampler is on Auto or DTV 480p so it samples the correct amount of pixels.
        #11313
        Anonymous
          Aww, that’s a shame.
          Btw, the Wii’s 480i output seems a lot sharper horizontally, but on the OSSC, 480i means bob deinterlacing, so while you gain horizontal sharpness, you lose vertical sharpness and image stability. Not a worthwhile trade.
