Blank LCD Screen no output
  • #52034
    SullDaBull
      Hi All
      Powered on the OSSC today and nothing… Just a blank LCD screen and no output. Any thoughts as to what the issue might be or where I can start to troubleshoot?
      #52052
        1.6 or 1.7? Purchased from us or elsewhere?
        #52063
        SullDaBull
          Purchased from here but I’ve managed to kick it back into life. Oddly inserting a micro SD card into it kicked it into life. So that’s good. Hopefully not a sign of issues to come?
          #52085
            Definitely not normal.
            #52989
            Santos
              Hi there,
              Same issue here with OSSC 1.7…
              Connect PS2 console to AV1 and Hdmi out to my smart TV Samsung UE40D6100..
              G
              Sound works, OSSc display AV1: RGBs 625i /15,59Khz 49.91Hz
              But blank screen remains on TV
              Any help?
              #53011
                also cured by inserting an SD card??
                #53014
                Santos
                  I tried to put SD card and nothing change.
                  Also did a FW update and now is 0.90a, my tv shows the menu of the OSSC, I can hear the sound of the game inserted on my PS2 console, but black screen remains on tV.
                  Changing mode on the remote control keys #1 #4 #7 only in key #1 getting sync
                  AV3 port is working… Tv without imagem of the input are only on AV1 (scart) even changing scart cables
                  #53015
                    Ok, not related to OPs issue then. Sounds like you are not using properly wired RGB cables. You must use RGB cables with OSSC. Open another thread if you need further assistance.
                    #58396
                    SullDaBull
                      Thread revival….My screen has given up the ghost.  Slowly faded over time and now failed and I’m only left with backlight.  I’d like to upgrade to a version of code with the onscreen menus.  Is this possible now that I cannot see the screen? I do own a remote so could step through to the upgrade selection if I knew the exact steps?
                      • This reply was modified 3 years ago by SullDaBull.
                      #58406
                        It’s possible, but the steps may depend a bit on the firmware version you have so it’d help if you can roughly remember the version you have.
