Buzzing audio with cmvs neo geo
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › Buzzing audio with cmvs neo geo
  • #15755
    netizensmith
      As title. Snes works OK mostly (occasionally screen jumps, will try better quality cable) but my neo geo audio has a buzzing to it. I get the same buzzing if I use an av amp or direct to the TV. Any suggestions?
      #15756
        To my understanding, audio buzz can be caused by poorly-shielded cables, and your best bet for avoiding buzz is fully-shielded cables.
        There may still be a slight buzz from the analog noise floor which I don’t think you can fully eliminate.
        #15768
        netizensmith
          Worth trying to source a better cable I guess but wouldn’t I get that same buzz when plugged directly into the Scart socket of the TV?
