C64 Component Mod : Missing RED
NewHome Forums C64, C128 & ZX Spectrum Video Enhancement C64 Component Mod : Missing RED
  • #45157
    a7mag3ddon
      Hello,
      I got my c64 mod board back in DeC 2020 i fitted it no problems, tested it for a couple of days then put the C64 away.
      Yesterday i received a new MegaC64 switcher board so pulled out the c64 again, upon startup the screen was not the correct colours, at first i thought it must be my OSSC which it wasnt (went to rv directly) so dug out another set of cables including the small jack to RCA i had, after pulling out BLUE the screen went green, aftwr pulling out Green the screen went off after a process of elinination i worked out the RED colour was missing.
      I took the c64 apart reseated the flat cable still the same so left the c64 on whilst i googled to see if it was a problem for anyone else.
      Turned the c64 off then back on again and all colours are back as normal, even the day after the colours are normal.
      Is this a problem with the mod board or the vic or the sockets?
      Im very worried that if i pack it away again it won’t work when i try it again and then of course the mod board is almoat half a year old and harder to replace under warranty.
      I read on another post there may be a firmware update so might also try that
      Anyone have this issue before ?
      #45807
        Who fitted the board for you, maybe it’s a loose connection?
        #45816
        a7mag3ddon
          Hello,
          I fitted it, all sorted now, i needed to do the oscilator mod on my PAL board and update the firmware.
