Capture Card
  • #19132
    lizzie
      I’m just getting back into streaming from like 5 years. I’m basically looking for a capture card be it internal or external that works easily with my new oscc. I just bought a new higher end pc so anything thrown at it should work. I’m mostly going to be doing famicom and super famicom. My famicom will have an rgb upgrade and using retro gaming scart cable or the hd retro vision cables and if i’m lucky possibly going through scartsw_lite later.
      Now that’s not to say that I won’t possibly want to stream something from my ps3 or switch later. So i’m looking for something that does both and where I can be slightly lazy with it.
      Thank you.
      #19315
        Hi Lizze, take a look here for some models that have been tested – https://videogameperfection.com/forums/topic/capture-card-compatibility-report-thread/
