color issue over RGB Scart (with video)
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › color issue over RGB Scart (with video)
  • #26493
    PixelPauer
      my RGB-modded Mega Drive 2 and my Neo Geo both have exact the same issue, mostly with the color blue as you can see in the video.
      The video is from the Neo Geo hardware test, the 240p test suite on the Mega Drive shows the same behavoir.
      Both consoles are plugged in via Scart.
      Video
      It worked fine a few days ago. Can anyone help?
      Thanks in advance.
      #26496
      PixelPauer
          Is that one of our OSSCs?
          #26515
          PixelPauer
            I bought it from Aliexpress 4 months ago.
            #26516
            James-F
              Absolutely disgusting.
              This is exactly the reason why you should buy only from official sources like VGP.
              I don’t think VGP will provide support for these terrible clones.
              #26528
              Deleted User
                That looks like liquid damage, judging from the blurry picture.
                Could very well be one of the filters going bust through corrosion.
                #26529
                James-F
                  That’s a bad no-clean flux with super hot wave soldering machine,, resulting in micro solder splater all over the boards, melted plastic, and flux residue.
                  Terrible job.
