CPS Digital interface install on a CPS3 – need help!
NewHome › Forums › CPS2 digital AV interface › CPS Digital interface install on a CPS3 – need help!
  • #45712
    mathewbeall
      Hi Folks,
      I got this installed on my CPS3 about a week ago – and when I first fired everything up, I had perfect video – but for some reason, no audio at all.
      Since I have been troubleshooting this – the problem has gone from kind of working to not at all, and I just retried soldering everyhing from scratch and got the same behaviour.
      If C2 and HS are connected – the game won’t boot and nothing comes out the JAMMA edge (no signal lock from my OSSC).
      If I disconnect only these 2 wires, then everything boots up like normal and I get video/audio like expected out the JAMMA edge.
      I also noticed that the HS and C2 pad *appear* to have continuity to GND, even with nothing plugged in, but am not sure if that is expected behaviour.
      Any help would be appreciated!
      Thanks,
      Matt
      #45808
        Can you link to some photos of your installation?
        #45814
        mathewbeall
          Hi BuckoA51,
          I posted over here and have some pictures.
          https://www.arcade-projects.com/threads/cps3-digital-av-installation-troubleshooting.16698/
          Since then – after talking to marqs i replaced U9 and U16 (HS and C2 shouldn’t be going to GND). After that change, the system would boot up – but still no HDMI out on the board, so I am guessing I somehow messed up or blew some chips out. I have since ordered a new board and will try again with a new board.
          Matt
          #46011
            Please let us know how you get on.
            #46012
            mathewbeall
              The new board worked perfectly – I am guessing that somehow i managed to blow or mess up the board I was originally using. Everything is good now! My wallet is just a little thinner due to my mistake!
              Matt
