CPS2 Digital AV, Sound problems.
NewHome › Forums › CPS2 digital AV interface › CPS2 Digital AV, Sound problems.
  • #44738
    madrandomize
      Hi to all from Greece!
      I purchased a digital av interface for my cps2 board.
      The installation went very very well and i was able to get PERFECT image through hdmi.
      What works is:
      Image through hdmi
      Controls
      Scanlines
      The Image signal is very stable
      What Doesn’t work is:
      Sound…
      Let me explain in depth. I can hear the sound effects and the music but there is a static sound that is very loud on top of those sound effects.
      Here is a google link with a video displaying the problem and some installation images.
      https://photos.app.goo.gl/QP6LFxD8MuybsVYf7
      The sync cable i used is RG-174
      Also i dont have my cabinet to check if it has sound through the jamma harness but it was working 1 month ago when i tested it on the cabinet.
      The mess with the cables is a DB15 consolisation attempt that works well (i tested it on my input menu)
      The board also passes all the checks (RAM ROM) and i have the same issue with all the B-Boards i own.
      I am eagerly awaiting any input on the problem if you can help, or if you know someone that knows where to ask for more help.
      #44760
      madrandomize
        I fixed the problem. It wasn’t the coax cable although I changed it for a thicker one.
        It was a solder bead that has fallen between the legs of a chip i attached cables into it.
        It was causing a short. When I removed it the mood worked fine.
        #45502
          Glad you got it sorted!
