Hi all,
I recently received my DCDigital from VideoGamePerfection and installed it. However, during gameplay I noticed audio popping in every game I play. Also, from what I understand analogue video should still work after installing DCDigital. However, when using an RGB cable, the video is all messed up.
The things I’ve already tried to solve these issues without success:
– Reflow all solder connections on the ribbon cable going to the Dreamcast main board.
– Replace all capacitors on the Dreamcast main board
– Try a different PSU
– Try different power cables and HDMI cables
– Try a different television/ monitor and speakers
The Japanese Dreamcast I’m using never had any audio or video problems before using this DCDigital kit. Does anyone have an idea what might be the cause of these problems?
What I noticed, is the DCDigital came with a ribbon cable that’s different from the one on Black Dog’s website and any other site selling replacement cables. It’s orange instead of black and some pads and components are different from the black cable used in the fitting instructions. For example, the fitting instructions mention bridging JP1 on the cable, but this orange ribbon cable doesn’t have a JP1 pad.
Another thing I noticed, is that the ribbon cable was slightly folded inside the box when it arrived. I can only guess this happened during shipping, but it seems hard to believe a minor fold would cause problems like these.
