Dreamcase w/ Scart cable – only audio but no video
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › Dreamcase w/ Scart cable – only audio but no video
  • #35909
    Hao Zhou
      It’s my first time using OSSC.
      Input: Dreamcast w/ SCART cable (purchased from eBay)
      OSSC: latest model w/ 0.81a firmware
      TV: SONY KDL-60R550A
      1. I can see the grey window output when I turn-on OSSC
      2. I can hear audio but no video images
      I tried play around with setting but no luck.
      Any hints?
      Thanks a lot
      #35933
        You need to set OSSC to AV1 input using the remote or the left hand button on the unit itself.
        #35974
        Hao Zhou
          I already did that otherwise, it won’t play audio either.
          ossc led tells there’s signal but still blank screen on tv
          #35986
            What kind of TV?
            Do other consoles work?
            Is it a blank screen or “image not supported” ?
            Have you verified the cable is wired for RGB and not just composite video?
