Dreamcast TORO with OSSC
  • #22688
    gamingyoshi
      Hello
      I am wondering if I can use just the VGA output on the TORO to the VGA input on the OSSC to do everything possible with the TORO & OSSC (240p / 480i / 480p) Are there any reasons why using SCART or VGA would be superior?
      Thank you for your input! : )
      #22693
      ErebusMaligan
        Bucko explains in this thread why you might prefer to use the scart output on the toro.
        Dreamcast Toro + OSSC = Scart or VGA?
        Either will work however if you have a particular preference due to other switches/cables/connectors in your setup
        #22698
        gamingyoshi
          Thank you! I think I will stick to VGA because I am sending the signal from my toro to my extron, and my dreamcast is a bit far away from my rack. It is much easier (and cheaper) to find a long quality 15-pin to BNC cable than a SCART to BNC. Hopefully I can dial it in well! Thanks again!
