DVI mode outputs red instead of blue
- This topic has 5 replies, 3 voices, and was last updated June 16, 2022 at 9:41 AM by .
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › DVI mode outputs red instead of blue
My OSSC has been epic, I want to use it with an old 4:3 monitor I have, it only has DVI (Samsung XL20) to get any picture I need to change to DVI mode but then a blue C64 (via Koryuu) BASIC screen outputs in red.
The monitor is fine, the C64 output is blue over HDMI and I’ve tried different HDMI to DVI cables.
Can someone please help?
Thanks.
Richard
It could be that the monitor doesn’t like the formatting of the signal. When I encountered the same problem, adjusting the horizontal backporch up or down a step helped fix the RGB order.
Fingers crossed! 🤞
Thanks, I don’t see a test pattern when I power on the OSSC connected to the XL20 as the monitor doesn’t get a signal until I change the OSSC to DVI mode.
An update, I used an HDMI to VGA cable with a VGA to DVI-I dongle and I get the correct colours, obviously I have no need to change the OSSC to DVI mode.
You can change the OSSC to DVI mode and still see the test pattern. If you save settings DVI mode will also be retained.
Thanks.
Richard
Fingers crossed! 🤞
Thanks, that didn’t work though.
What colour is the test pattern image when you first power on the OSSC?
