External Capture Card for OSSC?
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › External Capture Card for OSSC?
  • #35798
    Opaque79
      Is there any external capture card that can capture all OSSC modes (PAL and NTSC)? All the ones I have seen in the capture card compatibility thread are internal ones. I would much perfer an external card. Any suggestions?
      #35842
      SavagePencil
        Any USB-based capture card is going to introduce compression, usually 4:2:2. That said, this cheap guy is said to work across all OSSC modes: https://www.amazon.com/PUTELTAL-Capture-Dongle-Recorder-Streaming/dp/B0818M8TW1
        #35843
        Opaque79
          Sorry. I should have said that it needs to be from UK. That one isn’t sold on Amazon UK so I need an external capture device that will work with all OSSC modes (PAL and NTSC) and needs to be from Amazon UK or any UK store. Any suggestions?
          #35913
          Opaque79
            The reason I need this is because my switcher and the splitter I have don’t play nice. If anyone knows of any compatible external devices that will work for all OSSC modes (PAL and NTSC) and is available at a UK store, please let me know ASAP.
