Hi, I just received my OSSC Pro with the new Extra AV Out. I am seemingly not able to get any signal from the Extra AV out composite output. Are there any settings I have missed in order to make it work? The S-video and VGA outputs are fantastic and seems to be working correctly.
I have set the output mode to S-video+CVBS+RGBS, but I have also tried all the other options. I know it’s not the CVBS cable as the cable works with other adapters and consoles, and I also know it’s not from the TV as the TV receives composite signal from other sources as it normally does.
I’ve tried to output in 240p and 480i, which works when I use S-video and VGA with sync converter to RGB scart. There does not seem to be any signal coming out from the CVBS output. I am at firmware version v0.83. Any pointers?
This topic was modified 1 month, 2 weeks ago by
Dorgark. Reason: Grammar
Dorgark.
